I finally found out the cause of the clicking in my engine . I took the pass. valve cover off and found #6 rocker extremely loose . I took it off and inspected it and it hasnt lost any bearings , so I looked at the pushrod next . It was so very slightlybent , and the only way you could tell was on a piece of glass . This surely couldn't be the culprit , so I put the pushrod back on the lifter and pushed down on it to see if I could get the lifter to budge and it wouldnt move. Usually you can get them to move very slightly . All of this checking leads me to believe the lifter is collapsed .
My question is , if I take it apart and find it grenaded , then most likely it has sent metal throughout the motor . If I do find it to be this way , my best bet would be to rebuild the motor wouldnt it ? I want to repair it correctly , so I wont have to do this but one time . Any insight will be much appreciated .
Thanks guys !
Joe
