My TSP 396 Stroker missing HP-Update
Old Sep 19, 2004 | 04:01 PM
Taphee6's Avatar
Default My TSP 396 Stroker missing HP-Update
Well after months of adjusting the valves and tweeking the motor I shoot off a 11.65 run (NA) at 114 MPH at the track. During this run I was still having issues with the tune. There was 4 degrees of KR, I hit the rev limiter on the 2-3 shift, I blew a p0742 code and spun slightly on the line. Not to mention the car scaled in at 4124 LBS. So, I really think the 390 Hp on the dyno was incorrect. Now if I can get the tune down and put the car on a diet I think I may be shooting off some very low 11's. Thanks to all of those that helped out with suggestions. Also if there is anyone willing to help with the tuning I would be happy to email the .bin file.
Thanks guys,,,,
Old Sep 19, 2004 | 04:35 PM
CHRISPY's Avatar
how does your car weigh 4124 pounds?
Do you have 400 pounds of stereo gear in it?
Old Sep 19, 2004 | 04:36 PM
brewerz28's Avatar
what kind of car is this motor in. at 4000+ weight is it a impala or a truck or what. just curious
Old Sep 19, 2004 | 04:46 PM
Taphee6's Avatar
Default Reply
In a WS6 convert with an iron block, 6pt full cage, Spoon susp and a 50 lbs tool box in the trunk. Had no place to put the tool box...
Old Sep 19, 2004 | 08:38 PM
pdd's Avatar
pdd
thats a big momma
Old Sep 19, 2004 | 09:06 PM
cyphur's Avatar
Thats a BIIIIIIG bitch.
Old Sep 20, 2004 | 05:37 PM
Viper's Avatar
Yea, but a big bitch pulling 11.65's!!!!!!!!!!!! Not bad at all!
Old Sep 20, 2004 | 05:39 PM
Squintz Palladoris's Avatar
Keep it in the circus!
Old Sep 20, 2004 | 05:40 PM
Goddamn! Thats movin out for that much weight!
Brad
Old Sep 20, 2004 | 07:21 PM
Taphee6's Avatar
Thanks Guys. I was very happy that the car got up and went like that. As soon as I get the trans and tuning issues worked out I think it will be even better. If not, here comes the Trex....
Old Sep 21, 2004 | 05:52 AM
antz01ta's Avatar
10 Second Club + 14 Second Truck Club
what cam do you have in the motor? i have a 396 stroker and it dont go for ****.
i'm using a 242 242 .595 .595 112lsa. made 460 rwhp 3920lb raceweight and went 12.0 @ 114.
Old Sep 21, 2004 | 11:08 AM
Juiced's Avatar
wow.....
Old Sep 21, 2004 | 12:19 PM
antz01ta's Avatar
Originally Posted by Juiced
wow.....
what heads & cam are you using?
Old Sep 21, 2004 | 10:07 PM
Taphee6's Avatar
Default Reply
Cam is a 237/237 595/595 112. Heads are Loydd Elliot 202/160's. To make sure we are talking apples to apples my stroker is an iron block 4.060 with a 3.82 Stroke...
Old Sep 22, 2004 | 02:42 AM
kumar75150's Avatar
I have a 396 with a 244 250 cam with trevor johnson ls6 ported heads and mine made 507rwhp and 460rwtq with 11:1 compression.
It ran 102 mph in the 1/8 with stock gears and 475rwhp.
Now it has 3.90s and 30 more hp. Hoping for 104mph on motor.
