oil pressure problem
Old Apr 3, 2003 | 10:01 AM
OnequickWS6's Avatar
Default oil pressure problem
i have a 98 TA...and my oil pressure at idle when cold is 40psi....when the car heats up at all...it drops to about 15-20psi....when i rev it increases..slowly..i replaced the oil pump yesterday....and everything is the same....(The O ring in the oil pump was still good, but i replaced it n e ways..)...what else could it be?
Old Apr 3, 2003 | 11:02 PM
Bombguy99z28's Avatar
Default Re: oil pressure problem
I had an oil pressure fluctuation problem... around 40 cold, dropped down to 20 warm and bounced around a lot. I also was down around 10hp or so.
Had a spun crankshaft bearing and a few spun rod bearings.
Old Apr 3, 2003 | 11:10 PM
pekkaz's Avatar
Did the spun bearings make any abnormal noise ?
Metal shavings anywhere ?
<small>[ April 03, 2003, 11:11 PM: Message edited by: pekkaz ]</small>
Old Apr 4, 2003 | 12:08 AM
Classic's Avatar
Could be the 0-ring even though you replaced it. I was really carefull with mine, but still managed to slice it apparantly as part of it came out in my oil filter.
Had to go back in and redo it. Now everything is good to go.
I'd suggest you look there.
Old Apr 4, 2003 | 10:28 AM
well my car doesnt make funny noises are n e thing....its running a little rich....checked the o ring....thats not it..
Old Apr 4, 2003 | 03:17 PM
Q's Avatar
Q
Has anyone used autotap to see if maybe the oil pressure sending unit is faulty? Example, what would it mean if your autotap display read the voltage for the oil pressure unit to be 0 and your gauge was actually at 10 psi or so?
Just a thought.
Q
