Thinking about this cam.. VE's inside
-LIFT___.006____.050____.200
- ID____ 285_____236____157
- ED____287_____238____159
- LCA___114_____114____114
- ICL___ 110_____110____110
- IVO___32.5______8_______-31.5__ BTDC (- indicates ATDC)
- IVC___72.5______48_______8.5 ABDC
- EVO___81.5_____57_______17.5 BBDC
- EVC___ 25.5_____1________-38.5 ATDC (- indicates BTDC)
- ECL___118_____118_______118
Overlap__58_______9________-70 degrees
Last edited by gomer; Sep 30, 2004 at 02:30 PM. Reason: Fixed error in .006 and .200 areas
Why such a high LSA?
1. Better idle (less overlap)
2. More intake clearance
3. Higher peak HP number
4. Broader power range
5. Moving the torque curve up in the RPM band
6. Nitrous friendly
I'm going to be running the new PRC dual springs that are have a little more pressure than the patriot gold duals. I plan on shifting around 6900-7000 normally aspirated.
- LCA___117_____114____117
- ICL___ 117.4____110____118
- IVO___25.1______8_______-39.5__ BTDC (- indicates ATDC)
- IVC___79.9______48_______16.5 ABDC
- EVO___80.1_____57_______15.5 BBDC
- EVC___ 26.9_____1________-36.5 ATDC (- indicates BTDC)
- ECL___116.6____118_______116
Overlap__52_______9________-76 degrees
Gomer,
Tough to figure out what'll work without more info...
Vehicle dynamics and flow figures would help...
Also weight of the valvetrain... The XER lobes are not friendly to heavy valvetrain...
Ed
Ed
Lift___int___exh
200___152__117
300___206__166
400___261__202
450___274__210
500___292__219
550___305__225
600___314__229
Lift___int___exh
200___152__117
300___206__166
400___261__202
450___274__210
500___292__219
550___305__225
600___314__229
Can your springs handle .625-.635" lift???
Ed
Are you building it for nitrous? You were looking at a wide lobe for that reason, but is there enough exhaust lobe for a what you plan to run?
Defintely not optimal for nitrous
Up to a certain point (relative HP) a nitrous specific camshaft design in not really needed. Since he's looking for a certain operating range, and the heads are in a higher Ex/Int ratio, there's going to be more to his specific design than just the "relatively" wide LSA and its resulting intake timing events. I think I'd go as far a stating I'd get more aggressive! Image that...
Basically I'm just looking at the overall combo that Gomer has and what his goals are, and see that the cam profile he's looking at doesn't seem correct. (At least to me anyway) Hey.... but WTF do I know... I only know 5.0's, right?
Ed
Just throwing out some ideas
Just retorting some comments made by "frequenters".... I'm in a fiesty mood... Just turned 48 and I'm feeling old...
...back on topic... sorry...
Ed
