Cam advice? Split, reverse split or equal?
if the exhaust of a Dodge ram can be flowed, I sure fixturing can be modified to do an LS1.
To all: I not interested in any pi$$ing match on what is best, what solves all. Most have a "camp" they want to support and that great. I have posted some things I have found over the years that I know work. The main thing I try to get across is a what works for someone may not be ideal for what you have, thats all.
Chris
You just proved, box cam A which happened to be a reverse split isn't as good as box cam B. And automatically jump to the conclusion that reverse splits are designed for top end power?
One cam should meet the criteria for the setup. Throwing 2 box cams at it, and one works better means....
Outta compare more than .050 specs also.
i proved that going to more duration over exhaust brings the power band higher in the rpms. i even did it with the VHP 047 cam using DD2003. stop. read, ingest, learn. you keep saying a reverse split cam is needed for us intake restricted LS motors. and everything here proves me right. the intake just isn't that restrictive as people think they are. unless you want to spin the motor way beyond the intakes capabilities.
i'll clarify one last thing.
See, one setup to the other may seem sooo close, but yet they are more than likely not when you bring in the complete details. Thats why I'm not a big fan off "off the shelf cams". Not one cam, will fit everyones needs. I understand that Vinci has tons of R&D, but that was my only point.
Good discussion guys
Chris
Same driveability at all rpm (no loss)
35-60 more rwhp in the upper ranges (huge gain).
For my LS1 project car #3 (I'm on 5 now), it was the IDEAL cam. That doesn't mean it would be ideal for others in this day and age. Remember, there have been lots of advances in reducing intake flow restrictions. 2-3 years ago, crutching the intake with more duration made more power everywhere. The fact that mine picked up in the upper ranges proved to be an even bigger bonus for me!
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
I have been the webmaster for Yank for years. I just posted dynos on their sight to make it easy to post here.
sometimes too much information can cloud the mind.
Chris and other folks who design motors for a living don't bet the farm on DD2003. To base any performance claims, trends, or claim absolutes on design on the results of a software package without real world empirical data to verify those results I feel is wrong on many accounts.
Here are several points from the Cam Thread which address some of the points made thus far.
Stock Intake to exhaust ratio is ~70-75% before the exhaust is bolted on.... the intake will definately restrict the heads. So, figure about 80% ratio is what you'll end up with. Due to runner length and the current lack of cost effective shorter runner intakes, the LS1 is limited to a 4800rpm torque peak.... thus 6200-6400rpm HP peak (due to the wave of the incoming intake aircharge as it bonces between the closed intake valve open air plenum).
When I do a cam for a setup like this, I go for max cylinder pressure under 6200rpm.
The area most cam companies error on is the exhaust. This causes problems with these limited intake designs. The exhaust VE's are the most important on these setups.
Simply put, on an N/A motor the intake aircharge is not assisted. (leaving wave dynamics of the aircharge out for a moment).
After the combustion stroke there is tremendous pressure in the cylinder. As soon as the exhaust valve cracks open it flows a LOT of air. It's basically boosted out of the cylinder if you want to look at it like this. Having the exhaust valve open too early not only costs heat (power) velocity through the exhaust runners, it also empties the cylinder before the intake valve is open enough to take advantage of the pressure differential. (in a limited overlap/smogable camshaft this is especially true) This causes exhaust reversion and is one of the key factors in surging problems.
By the airflow reversing course it is loosing a lot of it's inertia. Typically this is overcome before peak torque however. So only low-speed issues are present. At the track these motors are always above 4500rpm so this does not affect track times too much.
Stilll....there is significant power lost by allowing reversion. So it makes sense to open the exhaust valve a little later and increase the overlap a bit. By adding advance into the camshaft this makes the problem even worse as now you're opening the exhaust a few more degrees earlier.....and shortening the effectiveness of the intake unless you have significant overlap flow to over come this.
Simply put, advancing a cam makes it more exhaust bias relative to TDC. Retarding a cam makes it more intake bias relative to TDC.
Now, I'm not saying a reverse split is always best. I'm not saying a symetrical is always best, and I'm not saying a standard split is best. I don't think Chris is either.
What is being said is that your motor is an airpump. Once you understand ALL the factors that affect that airpump you can optimize that airpump for maximum pumping efficency. In effect, many of these cams specified will work but you may be leaving a bunch of power on the table.
Let me cite an example.
I've seen three of Chris' grinds one was for combo X, and the other was for combo Y, and the final one was for combo Z.
Without getting into the specifics one was a reverse split, the other was darn near symetrical, and the last one was a positive split. Does that mean Chris is in all threee camps. Nope, Chris isn't in a camp except the proper camshaft design camp, which is where a lot of other folks need to be. He designs cams based on a motors needs, and the duration, split, LSA, etc... are byproducts.
You already have a camshaft that is exhaust bias'd. Advancing it, is only making it worse, is it not?
Just a question. Dont jump me standard splitters.
ad as far as DD2003 goes, i don't live and die by it. i already said that. i said it does pretty good at showing a pattern of what's going to happen. and it hink it did a pretty good showing of it. matched pretty much the dyno of patrick's. a little loss under 5000 rpm. then starts gaining after 5500.
The TR224 seems to be a real favorite around here. Maybe I should look into the TR227/224?
222/224 is not a reverse split cam.
That is a standard split or traditional split cam.
Combination. Period. Whether it be for something to get grocerys in or something that needs to haul 3500# down the track under 10 seconds. Combination, Combination.
As far as reverse splits goes vs everything else. . .lets back up a little to the basics. We all agree an engine is an air pump. The CORRECT cam doesn't care about what name you label it, it cares about getting the right amount of air in and out to accomplish a power goal at a pre determined rpm band. With that said, I feel that is why some OEM's, Honda and Misubishi, use reverse split camshafts in production cars because it is the most effiecent way to get air in and out to make power.
So I disagree with you that reverse splits are drag only. They are like anything. . .if they are the best choice to do a job, that is the part to use. Again I am not pro anything, I try to make people think.
Chris
So, the way that you are ( oh geez
OOOOOPS. I'm to late. Chris just posted
edit: yes between him and me it's a pissing contest.
Chris
