Custom Cam?
Old Sep 30, 2004 | 09:15 PM
VortechC5's Avatar
Default Custom Cam?
I haven't been able to find quite the cam that I want to run and am considering having a Comp custom cam ground. Is this something that I need to do through Comp or can vendors have this done for me. Is one way better than the other?
Old Sep 30, 2004 | 09:19 PM
52172's Avatar
Is what you need to do is find a vendor that will flow test your heads and then have the cam custon ground to match the flow of your heads. If you are running unported heads then it is not as important to have a cam custom ground.
Old Oct 1, 2004 | 11:48 AM
VortechC5's Avatar
Thanks for the suggestion.
Since I am using AFR heads I decided that I would call the expert, Tony Mamo. We talked for a bit and he not only recommended a cam but is taking care of having the cam ground for me.
Taking into consideration emissions and boost we decided to use a 220/224 on a 115+2 ground on XE-R lobes.
Old Oct 1, 2004 | 02:26 PM
1Hawk's Avatar
LS1TECH Sponsor
Sounds Like a good cam...Good Luck with it
Old Oct 1, 2004 | 02:53 PM
01badz28's Avatar
Hey man,
If you don't mind me asking, about how much does it cost to get a custom cam ground? Thanks!
Old Oct 1, 2004 | 03:12 PM
cyphur's Avatar
Depends on who you go through. You could call thunder, or tsp, futral....and see what they charge. tsp and thunder actually list that on their website i do believe. futral you'll have to call.
Old Oct 1, 2004 | 05:43 PM
VortechC5's Avatar
I paid $395 through AFR for mine.
Old Oct 1, 2004 | 07:28 PM
Ed Curtis's Avatar
Cool
Originally Posted by 01badz28
Hey man,
From $400 to $450 depending on who's doing it...
Ed
Old Oct 1, 2004 | 07:39 PM
Sport Side's Avatar
thats a pretty good deal, seeing as you can get a box cam for 400.
hmm, spec'd to your engine or a best guess camshaft? sometimes a bad guess if your not careful.
Old Oct 3, 2004 | 09:31 AM
Jon @ Speed Inc's Avatar
Just to put it in perspective for everyone, we offer any Comp Ground cam to our specs or yours for $379.99. Right now in the sponsors section there is even a thread where for this week we are offering a sale price of $364.99 shipped.
