408 Not putting down the power
Old Oct 10, 2004 | 09:28 PM
Mike K.'s Avatar
I also had problems with the Comp R's and have seen my graph look like yours as well, swapped back to stock lifters is what helped me, we even tried adjusting the preload but it did not seem to help, I did have the yella terra rockers though so maybe that was part of the problem, seems like comp r's and yt's don't get along too well.
Old Oct 10, 2004 | 09:41 PM
Country Boy's Avatar
Senior Member
I switched to YTs with my Comp Rs and the problem went away. Heres a before graph with Comp Shaft mounts and Comp R lifters: http://forums.scfba.net/album_page.php?pic_id=109
I switched to Yella Terra rockers and tightened up the preload a bit and this is what I got: http://forums.scfba.net/album_page.php?pic_id=144
Old Oct 12, 2004 | 08:28 PM
johns01ta's Avatar
Default On the dyno again
Well...we put the car on the dyno again and nothing changed. We set the preload right between 1/2 turn and 3/4 turn (previously had 1/4 turn). Absolutely no change in HP what so ever!!! The same dip around 5200rpm was in the exact same spot. What would you think about the shaft-mount rockers (Comp)? Could they be too heavy? I would think that if they were too heavy once the power dipped it would stay gone rather than come back up? Anybody have any ideas?
Old Oct 12, 2004 | 08:31 PM
johns01ta's Avatar
How much is "A BIT"
Old Oct 13, 2004 | 07:27 AM
SAM98WS6's Avatar
.008-.010 cold is the recommended and I didnt have this problem at all with my Comp Rs. Tightening them up a little from .005 is an easy thing to try. I wouldnt be too sure it isnt a TB problem too if not a header issue but the dip back up points to something mechanical/electrical or tuning. Stock ported TB is problably maxed out but I wouldnt think it would cause a dip. Anyhow you have room for improvement here and thats a good thing.
Just curious about your plugs and gap?
Old Oct 13, 2004 | 11:59 AM
strokedls1's Avatar
I would of put a bigger cam in that thing. Not necessarily any more lift, but more duration. Sounds like you have some valve train harmonics causing that dip. Some kooks 1 7/8 would pick up some power too.
Old Oct 21, 2004 | 01:18 PM
johns01ta's Avatar
UP DATE
Got the car off the dyno last night and the dip in HP is fixed. we pulled the comp shaft mount rockers and put the stockers on. we are still down about 20hp. we have one full turn of pre load on the comp R lifters and i thank this is to much so we are going to shim them up and try it again. any one besides Taphee6 set comp Rs with a compression tester? I was going to set them like a half a tune and try it.
Old Oct 21, 2004 | 01:57 PM
LASTLS1's Avatar
6 Second Club Moderator
I run comp R's. I set mine at .014 cold, no problems. I run Jessel shaft mounts.
Old Oct 21, 2004 | 10:39 PM
Taphee6's Avatar
Default Comp test
John
Run a compression test on all 8 Cyl. If the numbers are all over the board the preload is not set right.
Old Oct 21, 2004 | 11:50 PM
H82BBad's Avatar
do not run the comp r's at less than .015 preload. they will come apart.
Old Oct 22, 2004 | 06:45 AM
SAM98WS6's Avatar
my comp R's are at .008" for 6000miles now...the above statement is incorrect...even according to comp cams...
Old Oct 22, 2004 | 02:10 PM
  #32
H82BBad's Avatar
mine came apart in under 3000 miles. .005 on the intake and .013 on the exhaust. Not to mention several other peoples lifter have also came apart. Just because yours have not came apart yet does not mean they are not going to. The cups will get beat out of the top of them eventually from cold starts. When it does do not say I didn't warn you.
