Does an LS6 cam require different pushrods with stock heads?
A sponser here told a friend of mine that he has to have different pushrods to run the LS6 cam in a stock LS1 headed car?? Am I missing something or is the shop wrong? I thought you only need custom pushrods if your heads are milled... It was something about the LS6 valve stems are longer????? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Just got done installing 2002 Z0-6 cam and LS6 springs used the same Factory pushrods no problem.
2001 ss camaro conv.
Well, I won't be getting the heads milled... I'm just going to go with the LS6 cam and springs. Just wasn't sure about the needing of the pushrods. If everyone is using the stock pushrods, then I'm going to order my cam and springs tonight! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
