Removing crank timing sprocket?!?!
Old Apr 6, 2003 | 05:30 PM
02NHRATA's Avatar
Default Removing crank timing sprocket?!?!
ok ok how do I get this sprocket off??? Replacing oil pump and going with SLP double roller timing chain and am held up with removing the old crank sprocket.
Thx
Old Apr 6, 2003 | 07:01 PM
LS1swap's Avatar
Default Re: Removing crank timing sprocket?!?!
You need a puller... None of my regular pullers would get behind it. So I used my harmonic ballancer puller ( like a gear puller but with four arms with slots instead of jaws) and caught it with the heads of three 3/8" carriage bolts. It came off pretty easily once I got it hooked. I haft to laugh. When I first saw the topic I thought you wanted to take off your reluctor wheel. I was going to say stop but then I read the post. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 6, 2003 | 07:17 PM
BigBake's Avatar
Do you have to drop the oil pan to do this?
Old Apr 6, 2003 | 07:22 PM
Argon Z's Avatar
i used my 3 jaw crank puller to get mine off
it is tought to get started but it comes right off.
Old Apr 7, 2003 | 01:46 AM
DreamWeaver's Avatar
Thx finally got it off what a pain was the hardest part of the swaps - cept for cracking the housing but thats another story lol.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Do you have to drop the oil pan to do this? </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">yes. Gotta drop the pan to remove the pickup tube off the oil pump.
Old Apr 7, 2003 | 09:01 AM
Fastest 35th SE.'s Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BigBake:
<strong> Do you have to drop the oil pan to do this? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Just have to pull the bolts on the pan and let it sit on the K-member. There is one 10mm bolt on the pickup tube, then the pump will come out.
