Time for a new motor.
Well, I had a valve spring explode into five pieces, you know what that caused. Still not sure if I can use the block of not. If the block is done I am going with a 402 iron block. If I can reuse the stock block, I'm thinking about an eagle 3.90 crank. I don't like the idea of stroke being bigger than bore. I have a decent set of home ported heads. They flow about 280@.550. Have full boltons. Looking to make about 425hp at wheels without spinning above 6200rpms. I was looking at the FM13 cam. I haven't seen many of these setups and was just wondering If I had everything figured out about right.Any suggestions?
Originally Posted by term
What kind of spring was it? Got pics of it?
