Cam Comparison
Old Oct 11, 2004 | 03:26 PM
MachoCamacho's Avatar
Default Cam Comparison
Has anyone done a test NA between the TR 224/224 114 and the TR 224/227 114? they're so close i was wondering how much of a power difference there would be if any? cause i'm looking into getting a cam to last a while, even through supercharging and/or heads.
Old Oct 11, 2004 | 11:41 PM
FASTONE's Avatar
Get the 224, if you are going to sc then you need a cam with more exhaust duration.Thunder can answer your cam questions.
Old Oct 12, 2004 | 01:35 AM
jrp's Avatar
jrp
SN95 Director
you can extropilate the difference from this:
Old Oct 12, 2004 | 03:33 AM
GTS346's Avatar
Thats a reverse split though the 227/224, he was interested in a 224/224 vs a 224/227 but it would probably be almost the same figures.
Ring thunder I'm sure they have done extensive testing on all there cams and will set you straight.
But going off that graph I would just go the 224/224 on 114, there seems to be a bees dick difference in all 3 graphs, idle might hurst with the 230 111LSA though
Old Oct 12, 2004 | 07:04 AM
99-LS1-SS's Avatar
STF Veteran
You guys are killing me with your statements.
Old Oct 12, 2004 | 03:24 PM
lol...so basically theres probly not gunna be much....i figured so, many people on other posts have said that the TR supercharger cam 224/227 114 is not a large enough difference in separation.
