What is a good FI cam
Old Oct 12, 2004 | 12:10 PM
Crittpen's Avatar
Default What is a good FI cam
Hello i am going to run 8 to 9 psi with a vortech and waht to put a cam in i have a 91 with a 2000 ls1 and can only run shortys with a 2inch y pipe there is no cats on the car it is a T56 i want to make it mean but want to be able to drive it every day if needed meaning i need something with good vacum and drivablity and do not want some thing that is going to blow the bottom end out what lobe speration lift and duration do you guys think also if you are running any kind of FI let me know the numbers and what you think good or bad and who makes good blower cams thanks for looking need all the help i can get
Old Oct 12, 2004 | 12:18 PM
conan's Avatar
Call dave at mti. I am going fi in 05 and I talked to him for awile about h/c setup for fi. Going with the R1 115lsa. not an expert by any means just my .02. Also go to the fi fourm and type cam in the search you will get even more info.
Old Oct 12, 2004 | 01:31 PM
PREDATOR-Z's Avatar
To keep it simple,
02/03 LS6 cam
