Force Fed High Performance(FFHP) heads?
Old Oct 18, 2004 | 11:13 PM
2ktransam's Avatar
It's not peak numbers that excite me it's how the motor pulls through the whole range. My peak numbers are not the greatest but I compared my dyno pull against a Corvette with close to the same setup but stock heads and on the same dyno and I was about 25 rwhp and 25 rwtq through the whole range until the 6000 rpms.
Old Oct 19, 2004 | 04:39 PM
ForceFed HP's Avatar
Suspended Sponsor Account
we did not design and setup 2ktransam's heads for peak hp numbers, we listened to what he told us he wanted and went from there. beside's he is running a "safe" tune and probably has 10-15hp that could have been seen if leaned out a bit more. still he is happy with his setup. we quarantee if you decide to work with us here at FFHP you will be happy you did.
