Are my shorties holding me back?
Old Oct 20, 2004 | 04:09 PM
jermzz's Avatar
Default Are my shorties holding me back?
I just got done with my head swap, stage 2 5.3L. I also have a TR 224, well i have had the cam in for a while. I can feel a small increase in power from the heads, but not too much, not rearly as much as I thought I would. Is it because I havn't tuned the car yet? I got the car tuned after the cam, but not after the heads. I also think it might be because I have JBA shorties and not LT's. Am I losing a lot of power out of my H/C cause of the shorties? how much? I'm wondering if I should order some pacesetters and throw them on before I get the car tuned.
Any input would help as always.
thanks.
Jermzz
Old Oct 20, 2004 | 04:29 PM
jermzz's Avatar
Damnit, clicked on the wrong forum!
luv2spd's Avatar
Yes. You are prob. losing a fair amount with just the shorties on there. The tune can also be a huge part of that as well since you'll be flowing more air.
Old Oct 20, 2004 | 04:36 PM
Bad30th's Avatar
The difference between the stock exhaust when it was back on and my Mac midlength setup is nothing short of amazing - I would speculate that the same would hold true for shorties vs. LTs, especially with a heads/cam setup.
I didn't expect it to be such a drastic difference, especially in the top end.
I would think I could even gain a little more by swapping to LTs (I got my Mac's several years ago used for super-cheap, and swapped in 3" carsound cats).
Bad30th
Old Oct 20, 2004 | 04:57 PM
jermzz's Avatar
So tuning and Lt's are going to give me quite a bigger jump in power then just the heads did alone without being tuned, right? But it will all go together once its done.
Old Oct 20, 2004 | 05:00 PM
XTrooper's Avatar
Yes, you're going to see a significant difference when you get your setup "balanced" and to answer your question directly, yes, those shorties are undoubtedly choking your motor right now.
Old Oct 20, 2004 | 05:46 PM
-IH8RICE-'s Avatar
Get that thing tuned it is the key to getting what you want from that motor.The header are holding you backalso but I would think the tune would be more important.
Old Oct 20, 2004 | 06:36 PM
jermzz's Avatar
I hope so man, i dont want 2 grand worth of no power
Old Oct 20, 2004 | 06:51 PM
cyphur's Avatar
throw some 1 3/4's in and get that bitch dialed in. you'll love the power bump
