Trex or MS3
Old Oct 22, 2004 | 01:15 AM
BlueSix's Avatar
Originally Posted by mnc2886
You got a big mother of a stall. You put a t-rex in there, you are going to take off like a bat out of hell.
In all reality i think his stall is on the small side for the cams he is looking at.
Old Oct 22, 2004 | 01:20 AM
2MuchRiceMakesMeSick's Avatar
A 4400 stall???
My friend has the G5X3 cam, its got a choppy idle but he is switching to a trex after hearing my car. Thats one hard loping daily driver
Old Oct 22, 2004 | 02:31 AM
ArticLS1z's Avatar
It's BIG, and you aren't gonna find out the specs. After the G5X2 debacle LG won't release the specs on their cams. You can PM Louis, he can get you some info about it. There is some info about it on page 4 of this thread https://ls1tech.com/forums/drag-racing-results/222889-new-cam-only-record-10-64-126-a.html
i wont buy a product i cant know the specs of....
Old Oct 22, 2004 | 02:32 AM
ArticLS1z's Avatar
4400 w/ a 2:8:6 str is small ?
Old Oct 22, 2004 | 08:03 AM
DAPSUPRSLO's Avatar
TREX, more overlap equals more power and this cam has a lot of it.
Old Oct 22, 2004 | 11:19 AM
BlueSix's Avatar
No it's not a small converter. It has been proven to be THE converter for SI cars. But with a cam that is in the lower 240's duration i would think you could go even larger to take full advantage of the cam's powerband.
Also i wouldn't rule out the Juggernaut cam. It may be the badass N/A stock heads cam out there. 01-Z went 10.60's with it on a nitrous tune and nitrous converter. With more stall and gear 10.50's wouldn't be an issue. Just because you don't know the specs i wouldn't rule it out. Louis said it's still got 75 thou clearance on stock heads....how much does teh TRex have?
Old Oct 23, 2004 | 04:00 PM
That or a 4000 stall is just about right for the power band of a trex. Hell the manufacture recommends a 4000 or 4400 stall check the web site www.thunderracing.com
Old Oct 23, 2004 | 11:11 PM
35th SS's Avatar
go with the trex.you wont be disappointed.
 Michael S. Palmer
