Lunati Cams....any input
Old Oct 24, 2004 | 06:07 PM
Yelo's Avatar
Default Lunati Cams....any input
*Cross-posted from Truck Performance*
I've pretty much made up my mind on a Vinci High Performance Cam but my brother and I were talking the other day and he's was raving about the Lunati cam that in his 5.0 mustang, I started looking a little bit and found some LS1 cams at fairly reasonable prices.......
Does anyone have any real input on them ??, I know only a few people on here run them.......is that because of problems with them or because they are a less-well-known name in the LS1 world ???
Old Oct 24, 2004 | 07:10 PM
WS-Sick's Avatar
Lunati cams are very well know in the LS1 scene. TSP used Lunati to grind my cam 231/237. They make good products. I'm definetely happy with mine.
Old Oct 24, 2004 | 07:32 PM
cyphur's Avatar
Lunati is better known for their bottom end products for LS1's then their cams...although their cams can kick *** too. Like WS-Sick said, TSP uses them for some grinds, some other sponsers do I believe. You can always call Lunati up and discuss it. Without going into detail(as I'm not knowledgeable enough to), different manufacturers have come up with different lobe profiles and VE profiles, which is why there is a difference when running a Comp Cam XER lobe, or a Lunati grind, or a Cam Motion lobe, et cetera. All of them work very well when used correctly
Old Oct 24, 2004 | 11:22 PM
SS SLP2's Avatar
Very happy with Lunati 231/237 -TEXAS SPEED grind
Old Oct 25, 2004 | 12:47 AM
strokedls1's Avatar
Lunati can custom grind whatever you want. I am on my second lunati cam and getting ready to order a new one from them. They are great people to deal with.
Old Oct 25, 2004 | 07:55 AM
JoeyGC5's Avatar
MTI uses them , Texas Speed uses them. As do many other board sponsers. I love my MTI C2 lunati cam
Old Oct 25, 2004 | 08:03 AM
Yelo's Avatar
Great !!!, I'm looking at a Lunati 218º/221º .526/.534 116lsa......pretty tame by the standards you guys live by but just right for a daily driven 5500lb truck with a stock stall, I know every one of you is gonna say it's too small but other that do you guys see any issues with this cam ??
Old Oct 25, 2004 | 01:12 PM
WS-Sick's Avatar
I can't see any issues you'll have with it. Why did you decide on that particular one? Now I wish I had gone bigger and I plan to this summer.
Thanks for somewhat correcting me Cyphur.
Old Oct 25, 2004 | 08:35 PM
Yelo's Avatar
5500 lbs, stock stall (for now...TT2600 in the future), 2.48:1 first gear (4L80), daily driver....it has to be 110% reliable or the GF won't even let me think about swapping the cam
Old Oct 25, 2004 | 10:46 PM
Magic Chicken's Avatar
12 Second Truck Club
If she doesn't know what cams do, how would she know if you threw some numbers at her? "Yes, honey. It won't be much different than stock."
Old Oct 25, 2004 | 11:42 PM
cyphur's Avatar
Couple this comment with the quote in his sig concerning marriage, and one has to wonder.
Is the truck yours? If so....what the hell is she doing having a say in the matter? If its y'alls...then I suppose its a different story.
Just givin you **** about the quote bro.
Old Oct 26, 2004 | 12:16 AM
kickassT/A's Avatar
mti stopped using lunati to grind their cams because they were having problems with accuracy. i'm sure that on their own cam, they are alittle better about it.
Old Oct 26, 2004 | 04:45 AM
apexman's Avatar
My MTI T1 cam is a Lunati grind. It has been a great cam. It is a 221/221/559/559/112. You can still get these from Lunati as well. Great cam, nice HP and Tq, nice lope!
Old Oct 26, 2004 | 11:56 AM
Yelo's Avatar
......Well, since WE own the truck (we've been together over 6 years...just never gotten around to getting married) it has to pass the GF test, but she's pretty easy to please as....as long as the truck will be reliable it's OK, because we live over an hour from the nearest large town and this is the only vehicle we own she gets concerned (understandably) when it acts or runs strange
I did look at that 221º/221º form Lunati too, my MAJOR concern is low-end torque....it takes alot to get a boat this big movin' so as long as I won't lose anything compared to stock I would gladly go that way
Old Oct 27, 2004 | 09:26 AM
Tommy Tucker's Avatar
"Well Honey this is the camlifier and it spins round in the enginemaphone. It makes the springamy-bits bouncificate and boomify the juicy-gas that makes the wheelies whirly and takes us along the road. "
It might work!
Old Oct 27, 2004 | 09:56 AM
DEE99TA's Avatar
You know, you need to replace the cam every so many miles. It is a preventative maintenance issue. You don't the cam to go out and blow the engine due you?
DEE
Old Oct 27, 2004 | 12:13 PM
marc_w's Avatar
You actually had me going for a minute... I was like, what's this guy talking about?!
Old Oct 27, 2004 | 12:29 PM
LSUxBlake's Avatar
If I'm correct, I think Lunati uses a hollow core for reduced rotational mass. I don't know if all LS1 cams are like that, I just know Summit lists that specifically about them.
Old Oct 27, 2004 | 01:09 PM
Unaffliated Racing's Avatar
All of MTI's cams are now Comp grinds. Also..lunati hasn't had a guy desiging lobes since holley bought them out. Have you ever wondered why all of their cam are odd number durations? That's because they are using small block chevy lobes on LS-1 cams...not lobes specifically designed for the larger journal. A 231/237 cam is actually a 228/234 cam. The lobes grow when put onto the larger bearing journal of the LS-1 core.
Old Oct 27, 2004 | 02:45 PM
Ed Curtis's Avatar
Talking
I'm sure Harold Brookshire (at Lunati) has something to say about that!
Ed
