Need pistons for 6.0L
I am in search of some forged pistons and rods for a 6.0L iron block bored .030 with the stock stroke. Which are the "best" and why? And what are these generally going for? I am looking for some that will be good for a n/a motor and then be able to take the beating of a super about 6 months down the line. Thanks.
I will have 6.0 liter pistons in about a week or so. I will have them available in +.030" and +.060". They will run $570.00 for the set with pins. Give me a call if I can be of any help.
Thanks,
Chris Gelineau
Diamond Pistons
877-552-2112 toll free
Thanks,
Chris Gelineau
Diamond Pistons
Eagle rods are not a bad option for low cost. I would most likely say to get them in a 6.125" or they even make the stock length, 6.100" rod. We wil have the pistons for either one of these rod lengths.
Thanks,
Chris
Thanks,
Chris
I have a set of ROSS pistons on the shelf, 4.030 bore with a negative 15cc dome with a 1.300 compression height. With a 6.125 Eagle rod (which we can supply also) it will give you a negative .005" deck height roughly.
www.agostino-racing.com
905-420-9195
905-420-9195
