GM MLS head gasket vs. GM Composite head gasket
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I have an 01 C5 that came factory with composite head gaskets. I thought I heard an ugly rumor that I can NOT use 2002 or later GM MLS gaskets. Is this true???
Whether the above is true or not can I use Cometic’s MLS heads gaskets???
![Lurk](https://ls1tech.com/forums/images/smilies3/lurk.gif)
With an 01 you can definitely use the 02 MLS gaskets... No issues at all.. If you have an older set of heads, like the 806's on 98's, they have a notch at the bottom that will cause a water leak with MLS gaskets...
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
What about the Cometic gaskets???
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
