Cometic (MLS) gaskets on 01 and earlier LS1s, is it realyl a No No
Old 10-25-2004, 03:53 PM
SideStep's Avatar
Default Cometic (MLS) gaskets on 01 and earlier LS1s, is it really a No No
Subject says it all....
I got my heads off and checked my piston deck height, looks like .007 to .008
Was ready to start ordering parts and was hit with the "you cannot use MLS type head gaskets with 01 and earlier LS1s" story....
Looking for experiences and options...
Any help would be appreciated...
Old 10-25-2004, 04:14 PM
Lesrace82's Avatar
If your heads have the notch out of them like hte 01 and earliers they will leak coolant.
edit. I didnt see the Cometic brand in the first post. Have had no experiences with those.
Old 10-25-2004, 04:44 PM
critter's Avatar
Cometics are not leaking on my 2000. Wasn't it earlier heads (98??) that had the problem?
Old 10-25-2004, 04:51 PM
Bo White's Avatar
The mid year '00 and up heads do not have tha cast in slot on the head surface. If you get the slot welded up like I do mine then you canuse what ever gasket ya want.
Old 10-25-2004, 05:29 PM
SideStep's Avatar
Thanks!!!
Can anyone send a pic of this "notch" ????
Old 10-25-2004, 05:38 PM
mach1's Avatar
I beleive you can use the cometics but not the GM MLS gaskets on pre 01's good luck!
Old 10-25-2004, 07:17 PM
ROCNDAV's Avatar
Does anyone have a picture of this slot? I would like to check my 2000 LS1 heads and my 317 heads. The LS1 block has nothing to do with this, just the heads, correct?
D
Old 10-25-2004, 08:15 PM
jerflash's Avatar
ya i like to see the notch
Old 10-25-2004, 08:20 PM
guadofreak's Avatar
TTT for the "notch"
Old 10-25-2004, 10:18 PM
SmaknaSS's Avatar
Their is a tech tip with pictures in my 2004 SDPC performance parts ed.1. parts catalog about the notch on page 166, It shows the 97-98 have the notch in the picture indicated by a red arrow.
Old 10-25-2004, 11:09 PM
Green Thunder's Avatar
Run cometics on my 01 no problem
Old 10-26-2004, 06:01 AM
DEEZ98Z's Avatar
I have cometics on my 98 with no problems so far.... been on there for atleast 5000 miles
Old 10-26-2004, 06:59 AM
SideStep's Avatar
Thanks for all the replies....
Old 10-26-2004, 08:44 AM
S_J_H's Avatar
Cometics or Mr Gasket Brand MLS are not the same as GM MLS . No problems with notched heads.
I'm running Mr.Gasket MLS with my notched 98 heads.
Old 10-26-2004, 04:52 PM
Bryan TTM's Avatar
i've used both copper & cometic...cometics are the best IMO...AND you dont have to o-ring...they hold LOTS of cylinder pressure...now as for the notch for coolant deal, i'm all ears on this one
Old 12-27-2004, 02:41 PM
ROCNDAV's Avatar
Does anyone have a picture of this notch?
Old 12-27-2004, 02:57 PM
777's Avatar
i guess not
Old 12-27-2004, 04:17 PM
ArKay99's Avatar
I have Cometic .040" mls gaskets on my 1999 C5 w/AFR 205's. No problems, but the AFR's don't have a notch like the earlier heads. If I am not mistaken, I think the 5.3L heads have the notch.
Old 12-27-2004, 04:49 PM
SideStep's Avatar
My 5.7 stage IIe heads from MTI have the notch also....
Old 12-27-2004, 09:09 PM
mr2guru's Avatar
I will take some pics of my LS1 heads I got laying here and someone circle a notch or where a notch should be, with an editor and repost...how about that 11pm cst
edit: NM found a pic of the "notch"
https://ls1tech.com/forums/attachmen...chmentid=14855
