Losing alot of oil since Cam instal HELP!
Anybody know what i should look for.
Ever since the cam install
ive been losing alot of oil
lost about a quart in about 2000 miles then lost another quart 500 miles after that
Thanks
Thanks
Restricted User
Leaking or burning it? If yo are leaking it, pull your timing chain cover. Use a bead of permatex in the bottom corners. Also replace the front seal. Very easy to do.
