ARP's or GM factory head bolts.
Originally Posted by Mirek
From what I understand it is true. A line hone is required/recommended per the ART stud I-sheet. Not for the bolts just the studs. Different torque values in different places means you should never switch back and forth. For this reason I am going with ARP bolts. A vendor can step in anytime. There are some nightmare scenarios around. I really wanted to go with studs but thats not likely now.
I use ARP studs on about 90% of my installs and never a problem with noise/oil consumption that would be associated with out of round bores..So no,there isn't any problem with studs
Originally Posted by jermstyle
I speed 90% of the time and never have a problem with cops.
I'd like to use studs, but not until I'm ready to pull the engine. Good luck!
