GTP S2 head question
Old Oct 29, 2004 | 07:47 AM
equandt's Avatar
Default GTP S2 head question
I just got my GTP S2 heads. They are 853 castings.
I found something in the intake port that I found unusual. The threaded hole for the intake rocker is open into the intake port, creating a hole in the side of the port. Is this correct. This hole is present on all eight intake ports so I assume it is correct.
Does the rocker arm bolt seal this hole when the rocker arm is installed?
Can this hole cause a vacuum leak or cause oil consumption problems by allowing oil to get into the intake port or will the rocker arm bolt seal the hole?
Thanks.
Old Oct 29, 2004 | 07:51 AM
Viper's Avatar
Use locktite on the rocker arm bolts. There's another post asking the same question on this page.
Old Oct 29, 2004 | 08:18 AM
equandt's Avatar
Doh! Now I feel like a dumb ***.
Thanks.
Old Oct 29, 2004 | 09:00 AM
1fastWS6's Avatar
I used teflon thread sealer. Didn't want the bolt to get seized up in there using loctite. They're hard enough to get loose sometimes as it is.
