Which Rods???
I ordered a set of Diamond pistons with a .945 diameter wristpin. All the aftermarket rods i see are .927 diameter rods. Can i use .927's or do i need custom .945 rods made?
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Did you order off the shelf diamonds for stock rods...if so you have to run stock. To run an aftermarket rod, not only do wristpin diameters change but compression height changes too (to account for the different length rod)
Fireball,
I'll have to ask Joe Prince, he ordered them for me. But on the invoice it says custom piston and they came with a .945 wristpin.
