Want to Change my cam
Ok I no longer live in CA. I am thinking of selling my 220/220 114 Thunder Racing cam and going with something more radical. I have an m6. I am looking for as much power as possible on stock heads with a wicked lope(The more the better).But I dont want a cam that only makes good power above 5500 rpm. So far I am considering the TR 224 with a 112 lsa, TR 230/224 111lsa, and possibly a custom grind with a 228/224 112 lsa. I also have LT's on the way plus mods in sig. Any advice
<small>[ April 09, 2003, 04:26 PM: Message edited by: RB185AFM ]</small>
i would reccomend a comp custom ground cam. if you are looking for all around performance i would suggest 224/224 .561/.561 114 with 2 degrees advanced. this should put your power range from 2200 - 7200 rpm
i would reccomend a comp custom ground cam. if you are looking for all around performance i would suggest 224/224 .561/.561 114 with 2 degrees advanced. this should put your power range from 2200 - 7200 rpm. if you really want to know for sure email me with your modifications at badboyspeed18@yahoo.com and i will help you select the best cam to fit your car
