How do I read the info engraved on a cam?
Stamped 2870 D
Engraved
3732R/3732R
HR 14+4
CC.
Y1438
Thanks for any help.
Stamped 2870 D
Engraved
3732R/3732R
HR 14+4
CC.
Y1438
3732R/3732R means it is a 244/244 .612/.612
HR 14+4 means most likely it is on a 114lsa and has 4* of advance ground in
Y1438 is the serial number, if you call Comp with these numbers, they can tell you EVERYTHING about the cam.
Shawn
Shawn
Shawn
whta is the measure to consider a cam as a big cam and another as small cam ? ive been trying to get an answer for this question since a long time but i couldnt ?
what i mean .. there is some cams that have reached the 240 duration wich is too long for the valve to be opended .. the result will be more air in or more exhaust out can the valve passage area (Valve hole) afford the the too much in and the too much out ... IT WOULD be crowdy which gana affect the performance .. what is the limit of the cam that after it u have to change or manipolate the heads ? please let me know ur opinion
