whats the cheapest way to do a forged 346
RedrocketLS1, We have the perfecr set up for you. We have a hand full of guys that have done what you want to do & it works great! The LS1 stock crank is a very nice crank, so with a nice set of rods pistons and rings you should be on your way. This is what I have for you.......
*Crower Sportsman 6.125 I beam rods $435.00
*Wiseco flat top pistons for3.905 bore $449.95
*JE 1/16, 1/16, 3/16 file fit rings $146.85
*Clevitte 77 rod & main bearings $72.55
You should be able to get your rotating assembly balanced for around for around $200.00. Not a bad price for a good solid rotating assembly! Let me know if I can help!!
6600 rpm clutch dump of death Administrator
You can also talk with Erik Koenig or Chuck @ HPE.
A good rod and piston combo IMHO which is pretty light, is shelf stock, and is reasonably priced also are some of the parts from Probe. There is a Probe 6.125" rod with a forged piston which compares favorably with the stock rod/piston combo for weight and has 4 cc valve reliefs. I think it might be less than the Weisco/Crower combo, but I can't say for sure.
1 Post
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
Piston Set: #14217-003 / 3.902" bore / -3 cc valve relief / 1.315" CH
Ring Pack: #315-0037 / 1.5-1.5-3.0 mm
UL 4340 Rod: #10667 / 6.125" - 2.100" - .927" - .940"
Probe FPS:
Piston Set: #P2600F-003 / 3.902" bore / -3 cc valve relief / 1.340" CH
Stock rods
Ed
I was just out in the warehouse and noticed we have a set of 3.903 bore pistons in stock. If anyone is looking, I would be willing to make a deal
3.903 bore, 6.125 rod, .927 pin, flat top 2 valve relief
1.5, 1.5, 3mm.....gram weight 456.8
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
8 second mod
i run a setup like your looking for. i got a custom pistion cut for spray. 1000
then i got rods, lunati pro mod come wth bolts. 600, eagle are a tad cheeper. i polished my own rods for oil issues.
arp mains and head studs well worth it. stock crank nitrated new berings. if you talk to tom at speed inc he can get the right stuff for you, and building the motor will save money. if not ESP>>>>> knows exactly what you need, and they are very affordable and build alot of 347 motors like mine and the one you want.
good luck. pm me if you want more details
