broke car
Old Nov 9, 2004 | 06:49 AM
blackws69's Avatar
Default broke car
first of not sure if this is the right forum. sorry if it isn't. well i had this anoying ping/knock/rubbing sound coming out of my right bank head. found a couple bent push rods changed them no change so last night i pulled the intake and holy crap there was a **** load of carbom build up in the intake. looked at the valves and the runners were half covered in the same thing. i mean this stuff was caked on. so i'm going to pull the heads today and clean them up. hopefully all that noise was just a stickey valve. my question is has anyone ever had that happen from spraying? i ran engine top cleaner through it but maybe i need two cans instead of one. the noise was kind os a rubbing noise so since i'm going to have it apart im changing lifters and rocker arms i already have a cam and heads done to it. so i'm prepareing for some busted up knuckles tonight. i going to arp head studs and one have problems puttinr the pass side head back on with these while the engine is still in the car? or would arp head bolts be better. also anyone know the torque specs for the head studs bolts? thanks guys and gals eric. hopefully this weekend i can do this again and not this
Old Nov 9, 2004 | 09:51 AM
silverbeast's Avatar
what kind of gasoline do you run?
Old Nov 9, 2004 | 10:21 AM
blackws69's Avatar
i only run 93+ in it.
Old Nov 9, 2004 | 10:52 AM
WS6FirebirdTA00's Avatar
if you live close to charlotte motor speedway come by my work and we could run my top end cleaner through. we have a bottle that feeds it slowly and does a great job. i have my intake off right now and looked at the valves and in the chamber and there is ZERO build up with 50000 miles on the car
Old Nov 9, 2004 | 12:59 PM
dissonance's Avatar
can you take some pictures? how many miles do you have on your car?
Old Nov 9, 2004 | 07:50 PM
blackws69's Avatar
well im about 4 hours from charolette. i tried that cleaner but there was so much in there it didn't take much of it out. i pulled the heads off today and the piston head and cc was caked. i was shaving it of them. the car only has 54000 miles on it. but it's been sprayed a few times. i'll try and take some pics of it.
Old Nov 9, 2004 | 07:55 PM
how was the intake, lost of oil in it?
Old Nov 9, 2004 | 08:00 PM
blackws69's Avatar
yep quite abit. the lifters were pitted a bit also in the #2 exg
Old Nov 9, 2004 | 08:03 PM
what year is the car? have the factory pcv system?
Old Nov 9, 2004 | 08:18 PM
blackws69's Avatar
it an 01 yep
Old Nov 9, 2004 | 09:16 PM
might wanna try a catch can or with the intake off do like i am and go with the ls6 pcv system
Old Nov 9, 2004 | 09:19 PM
silverZ98's Avatar
yea eric the catch can works pretty good you have seen my home made one havent ya? hopefully tomm i be feeling my self and i can come over and help ya with the rest.
Eddie
Old Nov 9, 2004 | 09:33 PM
yeah u can make that stuff cheap and if it doesnt work then u are only out 8 bucks. where u guys from?
Old Nov 9, 2004 | 09:38 PM
blackws69's Avatar
the one and only place 2 b Jacksonville, NC home of the few the proud the MARINES.
