What are the symptoms of a bad pickup tube o-ring?
My oil pressure at idle is 25 psi and it seems to get stuck around 35 psi even if I take it to 3500 rpms. I was thinking that my o-ring might not be sealing properly.
Re: What are the symptoms of a bad pickup tube o-ring?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Fenris Ulf:
<strong> My oil pressure at idle is 25 psi and it seems to get stuck around 35 psi even if I take it to 3500 rpms. I was thinking that my o-ring might not be sealing properly. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If its not sealing properly or has a tear in it then you will have low pressure.Better safe than sorry.Pull it apart and check it out for yourself.That is a nice motor that you have there.
Try switching out ur sending unit, i did this and had the same symptoms as you do and changed it out, and immediately got back to over 40psi at idle...
