comp cam lifters
Old Nov 11, 2004 | 11:24 PM
DietCoke's Avatar
Originally Posted by Bo White
The R lifters have a heavy duty locking retainer that holds it together and has nicer rollers on them. Other than that the ones that I am looking at they are identical(cc850 vs cc875).
The internal spring is MUCH stiffer, and they return oil more slowly, in turn keeping them more pumped up at higher rpms, as well. This is why they can handle more aggresive camshafts then the 850-16s
Old Nov 17, 2004 | 01:29 PM
zamboxl's Avatar
ok iam confused i just talked to comp cam and they said i had to latch them to 2-4000 i have no iidea what that is, did they mean torque it down?? how do i install this things. i don't remeber haveing to do all that when i put the stock ones in.
Old Nov 17, 2004 | 02:04 PM
94form2000z's Avatar
They were saying to set them up with .002 - .004 lash. I am not positive on the procedure to do this but it is imperative that you get this right! #1 reason I do not run those lifters. I'd get someone that knows what they are doing to set them up for you. Do not torque them down like stock lifters though.
Old Nov 17, 2004 | 02:08 PM
zamboxl's Avatar
any body out there know how to do this????
Old Nov 17, 2004 | 02:41 PM
zamboxl's Avatar
anybody???
Old Nov 17, 2004 | 02:47 PM
LOL patience big boy
Old Nov 17, 2004 | 03:52 PM
Unaffliated Racing's Avatar
ok..calm down. Yet again we need to discuss this. DO NOT confuse lash with preload. This is apples and oranges, we are talking about two completely different things. Lash is slack in the system, preload is just that..pre..loading the system. The pro mag lifters require .002"-.004" preload HOT..not cold. I would probably put .008"-.010" preload when cold. Zamboxl..you have a Pm.
Old Nov 18, 2004 | 10:09 AM
zamboxl's Avatar
lol yea good things come to those who wait. lol
Old Nov 18, 2004 | 11:28 AM
DAPSUPRSLO's Avatar
I am putting these in in the next few weeks (comp Rs). When the motor is cold I have heard that you should simply tighten them down until the pushrod does not move any more, and then you should only be at 1/8 to 1/4 turn to get to 22ft/lbs. Is this correct?
Old Nov 18, 2004 | 12:55 PM
After you take the slack out of the system(lash) you would give the ratchet about 1/16 of a turn on an adjustable rocker. If you still have a stock rocker, pushrod length and shims are the only ways to achieve the preload required. Comp makes pushrods for the LS-1 in .025" increments.
Old Nov 18, 2004 | 01:25 PM
zamboxl's Avatar
by stock do you mean 1.7 ratio??? actually i ma gona give you a call today and make sure i got all i need to put this on.
Old Nov 18, 2004 | 02:24 PM
  #32
DAPSUPRSLO's Avatar
Thanks alot. I am assuming you do not have to see the 22 ft pound mark then right?
Old Sep 3, 2010 | 08:02 PM
  #33
Fastdriver1992's Avatar
Originally Posted by PREDATOR-Z
Ok guys,
1- the 850-16 CC lifters will handle any lobe and lifts up to .600 very comfortably, so 875-16 CC "R" lifters are not needed.
2- CC recomends that adjustable rockers are used with Comp "R" lifters. (pro-magnums) so do not use them with non adjustable rockers, "search and you'll read why"
3- TR p-rods are fine and I believe cheaper.
u can run them with stock rockers. i did and my car ran 11.16 @ 120 mph so there is no harm to using the stock rockers
