gauging interest in lq9
Old Nov 10, 2004 | 11:04 PM
zcar's Avatar
Default gauging interest in lq9
i recently came across the new gen III 6.0l crate engines and was gauging my interest as a using one as a cheaper alternative to an ls1, but i had a few question i was hoping some of you could clear up. First off i was wondering as to if it shares the same mount locations as the ls1, is it the same block as the ls1 just made in iron instead? Will a t56 mount up ok? what about aftermarket... cams, heads, intake, are all these interchangeable between the motors?
Old Nov 10, 2004 | 11:40 PM
jrp's Avatar
jrp
SN95 Director
everything is interchangable sans stock pistons. only thing you'll need to do is tap an new hole for one of the alt brackets.
