01 ls6 cam?
Old Nov 14, 2004 | 06:01 PM
slow98Z's Avatar
Default 01 ls6 cam?
I have a 98z.I was givin a 01 ls6 cam and springs and was wondering if it is worth my time to put it in the car.I can't aford to buy a cam for a while so will I see a gain?
Old Nov 14, 2004 | 06:56 PM
HotRod68Camaro's Avatar
from what iv heard you will. and if u dont want to put it in wanna give it to me? lol
Kyle
Old Nov 14, 2004 | 07:18 PM
cyphur's Avatar
stock cam
duration@ .050 - 198.86 / 209.25
lift - .498 / .497
LSA - 119.45
01 LS6 Cam
duration@ .050 - 204 intake / 211 exhaust
lift - .525 / .525
LSA - 116
take a look at the difference of those specs, at how different they are. between the longer duration, higher lift, and lower LSA of the LS6 cam, there's no way you can lose power with this cam if installed correctly and everything functions as it should.
Old Nov 14, 2004 | 07:22 PM
Chris81's Avatar
You should see a gain, but the 02 LS6 cam will show most likely show a better gain since it is a little more aggressive, but for the money I would go for it.
Personally, I have the 02 LS6 cam untuned and it is JUST like stock driving around (just a little more noise from the valvetrain with Comp 918's) and it runs very well on the top end now shifting at 6200 (had the limiter moved). I did the cam and ASP pulley at the same time and noticed a huge difference in power above 4000 rpm. I just need to dyno it now.
Old Nov 14, 2004 | 07:27 PM
ArticLS1z's Avatar
cam runs great... im shifting mine @ 6600
Old Nov 15, 2004 | 03:00 PM
ktmrider's Avatar
For free it is way awesome! No down side to the swap. The 02 Z06 cam is stronger on top but the 01 will give you better low end. Enjoy!
Old Nov 15, 2004 | 05:30 PM
slow98Z's Avatar
how much differance will it be.what will i need to put it in.
Old Nov 15, 2004 | 07:16 PM
slow98Z's Avatar
anyone?
Old Nov 15, 2004 | 09:00 PM
slow98Z's Avatar
I've been reading, are the base circles differant on the stock cam and the 01ls6 cam?
Old Nov 16, 2004 | 09:43 AM
ktmrider's Avatar
Hard question to answer for difference as your current mod level would make changes over stock-to-stock.
From a base HP comparison you are looking at 330 LS1 to 385 Z06, torque 330 LS1 to 385 Z06. The dyno should show an increase across the board with the Z06 and higher gains in the top end.
For a very good, detailed listing of cam swap goto www.LS1howto.com, it is a wonderful site for most LS1 tasks including the cam and spring swap. It will also list all the needed tools and parts.
Have fun, let us know what you decide!
Old Nov 16, 2004 | 05:44 PM
slow98Z's Avatar
are the base circles different from each other on the two cams
Old Nov 19, 2004 | 04:07 PM
N20Silverado's Avatar
check this out:
http://www.idavette.net/hib/02ls6/page2.htm
Old Nov 19, 2004 | 10:49 PM
slow98Z's Avatar
Originally Posted by N20Silverado
THANKS!!! very helpful
Old Nov 20, 2004 | 02:27 AM
ULTIMATEORANGESS's Avatar
its a good sreetable cam for what it costs.i have an 02 ls6 cam.
since you got it for free thats an even better deal.
