Spring tool
Old Nov 14, 2004 | 11:33 PM
99SSinOC's Avatar
Default Spring tool
Is there a problem with using a normal spring tool? or using a normal spring tool break the bolts on the heads or whatever? Should I only use one specific tool for the LS1's cam swap??? Plz help... doing the swap tomorrow.
Old Nov 15, 2004 | 12:43 AM
Z28Venom's Avatar
I would stay away from the lever style tools.. They apply alot of pressure to the bolt.
The best tool by far is the Crane tool. Does to springs at a time.. The tool is simply awesome..
Old Nov 15, 2004 | 12:59 AM
ta_silver_bullet's Avatar
i had my heads off but i used a spring compressor from sears it worked just fine not the lever style but one that sits on the spring its an ohc style
luv2spd's Avatar
I agree. The Crane tool rocks! Makes the job much, much easier.
Old Nov 15, 2004 | 01:06 AM
Ferocity02's Avatar
I used the Larry tool. It's just a piece of metal with a hole through, but it gets the job done.
Old Nov 15, 2004 | 07:32 AM
Black Z/28's Avatar
Originally Posted by Z28Venom
The best tool by far is the Crane tool. Does TWO springs at a time.. The tool is simply awesome..
I agree. Sure, it costs a little more than other spring tools, but if you're gonna be doing more than 1 spring change over the life of the car then it's well worth the investment.
Old Nov 15, 2004 | 08:47 AM
Slacker's Avatar
I used the crane tool, Worked great! I wouldn't try it without it..
