I am building a 414CI 6.0L stroker... should I go iron or alum?
Old 11-17-2004, 03:22 PM
gollum's Avatar
ASA racing use iron truck block.
Old 11-17-2004, 03:29 PM
427's Avatar
The trigger wheel is on the crank which is ls1 in our case. The block has the same placement for the sensor so it will work in a ls1 car if you use a 24x wheel. So there is a possibility that a stock ls2 won't run on f car electronics but the block can be used for stroker engine's.
V max1500
We have not worked up a cost for this engine yet. We are going to make some pulls tommorow with a FAST manifold with 90mm throttlebody. What parts would you want on it? LSX intake or LS6 or without intake? It will be here on Saturday running on the dyno.
Kurt
Originally Posted by vmax1500
I am not quite sure what you mean by this... could you please elaborate? I assume you built a 402CI LS2 (4.00x4.00)? Are you saying that in this scenario the LS2 58X trigger will work with the LS1 electronics? Thanks again!
Old 11-17-2004, 03:53 PM
vmax1500's Avatar
I would like the price without the intake or TB... just the long block... Thanks
Old 11-17-2004, 04:54 PM
GuitsBoy's Avatar
So youre saying you simply need to use an LS1 crank, not the LS2 crank, if youre going to use LS1 computer. What about the cam sensor being in a different place? Are you using an LS1 or LS2 cam?
Old 11-17-2004, 05:16 PM
CHRISPY's Avatar
That is AWESOME news Kurt. Thanks for sharing!! I was curious on the crank pickup location. So it sounds like all that is needed is to extend the wiring and you are good to go.
Old 11-17-2004, 05:33 PM
427's Avatar
Extend wires for cam sensor and use ls1 crank. We are using ls1 cam. The cam "ring" is now on the upper timing gear so you need to use the ls2 upper gear.
Kurt
Old 11-18-2004, 08:48 AM
Black Sunshine/ 00SS's Avatar
Kurt
Kurt, got any pictures of that LS2 upper gear, so I can see what you are talking about? That's great news that any LS1 cam will work. I was concerned that a special cam would have to be ordered, and thus, bring up the cost.
Can you sell just the block itself?
Old 11-18-2004, 11:54 AM
427's Avatar
I don't have any pics of the gear. Come to our open house on Saturday with a camera!!
The block is one we picked up for testing. We would sell just the block once they become readily available.
Kurt
Old 11-18-2004, 11:56 AM
vmax1500's Avatar
And the price for the long block is..........
Old 11-18-2004, 11:59 AM
427's Avatar
We ran the engine today with a FAST manifold with 90mm TB.
With the new intake it made570hp and 529tq at the flywheel. The average's from 3000-6500 are 443hp and 486tq. Also of interest is this engine is making 425tq at 2500 rpm.
Kurt
The engine is a hyd roller cam. compression is 10.7-1. Mahle pistons (small dish) With a LS6 manifold and dyno headers it made 553hp and 523tq at the flywheel. The average's from 3000-6500 are 438hp and 481tq.
The cam sensor wires the same just extended the wires. We don't use knock sensors on the BS3 but that would just be a extension deal also.
We built the engine just to see if all the ls1 crank and cam sensor's would be compatible. We do have a customer that we did head and cam on 2 years ago that may buy the engine and put it in his Camaro.
Kurt
Old 11-18-2004, 12:02 PM
vmax1500's Avatar
Please tell me the price Kurt
Old 11-18-2004, 09:33 PM
  #32
427
427's Avatar
12,000. from valve covers to oil pan less intake. No core charges.
Kurt
Old 11-19-2004, 11:33 AM
  #33
93LS1RX7's Avatar
That seems very high to me for a motor that would probably make 480rwhp. That is silly. The curve sounds awesome but 12k??? and 480rwhp.
Old 11-19-2004, 11:50 AM
  #34
GuitsBoy's Avatar
Big displacement costs Big money. But it leaves big room for big power adders.
12K is not all that obscene for a long block, especially since its bleeding edge technology still (ls2 conversion). Just think, there are people who spend 30K on a c5r motor.
Old 11-19-2004, 12:04 PM
  #35
buymeavette's Avatar
AGREED if you did yourself,owned a machine shop, and had a tax ID to get all those wonderful parts at cost or below MSRP then maybe it would be from 6-8K. Sadly, for most of us, speed will cost the most money;however, it it wasn't for us the tuners would shove up high dollar cars for us to all day long. Its an expensive form of art.
Old 11-19-2004, 01:12 PM
  #36
93LS1RX7's Avatar
I agree that a lot of strokers are around 12k but dont they make more than 480rwhp? That was my point. I guess the HP/$ ratio seems awful when you think you could do a forged 346 with good parts for 8k and make over 500rwhp and still be able to spray it.
I guess the driveability would be a ton better with the stroker though and much more streetable than a strung out 346.
Old 11-19-2004, 01:39 PM
  #37
GuitsBoy's Avatar
BINGO
I dont see too many strokers making more than around ~500 RWHP. Remember that a 402 is only 15% more displacement than a 346. However radical cams keep their street manners due to the added cubes. The nice part is that you have a fully forged setup that will handle all sorts of abuse.
-T
Old 11-19-2004, 02:10 PM
  #38
Lafngas98Z's Avatar
You could build a 346 to make 500hp BUT thats peak. The 500hp 346 would be pretty radical, where as the 408 would make tons more torque, have a better/broader power band and could be daily driven w/o issue. Not to mention clean the 346's clock.
Old 11-21-2004, 12:23 AM
  #39
z-ya's Avatar
Kurt how much prep did the block need ?
Old 11-21-2004, 08:10 AM
  #40
427
427's Avatar
The block was new. We still went thru our normal routine: Align hone mains, deck block and hone with plate to 4.005.
Kurt
Quick Reply: I am building a 414CI 6.0L stroker... should I go iron or alum?
