cam ?
Old Nov 16, 2004 | 06:59 PM
slow98Z's Avatar
Default cam ?
I am installing an 01ls6 cam in my 98Z28 and was woundering if the base circles are the same on my stock cam and the ls6 or will I need different push rods
Old Nov 16, 2004 | 07:03 PM
conan's Avatar
Are you changeing your springs?
Old Nov 16, 2004 | 07:04 PM
git_sum's Avatar
not sure what base circles are but i dunno why you'd have to change pushrods. I know when i bought a cam i didn't have to use different lenth pushrods and my cam is much larger than the 01 ls6 cam. You should just be able to use the stock 7.4's.
Old Nov 16, 2004 | 07:16 PM
slow98Z's Avatar
my car already has 02ls6 springs and titanium retainers
Old Nov 16, 2004 | 07:21 PM
conan's Avatar
Like gitsum said your stock ones should be fine. I have thunders hardened 7.4 length works fine.
Old Nov 16, 2004 | 07:27 PM
LS198Z's Avatar
The base circle is smaler but when I had my ls6 cam in the 7.4s worked fine.
Old Nov 16, 2004 | 07:34 PM
slow98Z's Avatar
how much smaller?
Old Nov 16, 2004 | 07:43 PM
LS198Z's Avatar
I searched and found it is 19mm vs 19.7mm. I don't know if that is true or not.
Old Nov 16, 2004 | 07:46 PM
slow98Z's Avatar
So 7.45's are the right ones?
Old Nov 16, 2004 | 07:48 PM
LS198Z's Avatar
I would use the 7.4's
Old Nov 16, 2004 | 07:54 PM
slow98Z's Avatar
Thanks!!!
