Building a 408ci
man one big thing is your cam is tiny for your cubes!!!! You might be suprised at what a difference just a cam swap might do for you, and yes you need heads that are matched for your bigger bore as well. I bet you can see 550 + rwhp with the right combo
I know I wasnt expecting to build a 408 when it happened. I bought Stage 2 heads to put on my 346 and pulled the heads off and piston #7 had a hole in it. We decided to build the 408 and I had to stay with those heads. The cam choice was my engine builders, I guess he was trying to stay somewhat streetable. Around Christmas time I am going to do Stage 3 heads and a bigger cam and hope for 500 rwhp.
Dame
If you're looking for a setup that you can make 600HP with, Eagle would be more than plenty. I would recommend Eagle for anything up to about 800HP. After that, it would be ideal to upgrade to something a little stronger. Peace of mind goes a long ways. Callies makes a couple of nice LS1 cranks. They typically retail for about $1,600. If you really want the piece of mind, or you plan to make power numbers of 1000, the Lunati is where you want to be. There are other crankshafts available for the LS1, but for the most part they're overkill unless you need a VERY light crank, or you're going to be doing endurance racing. For those applications you should call Sonny Bryant or Moldex. Prices on these cranks can range between $4,000 - $6,000!
As far as pistons go, you can't really go wrong with JE or SRP, especially if you're looking for a street cruiser. If you're looking to build something that can run with the fastest of them, Wiseco or Mahle would be a good choice. They might also be worth upgrading to if you don't want to have any worries, but I haven't seen any problems with anything from JE or SRP.
As far as connecting rods, it's the same story as the cranks. If you're looking for your car to be a street cruiser, Eagle's going to be your best bet. Those H-Beam rods they sell are much tougher than what people think. The Lunati Pro-Billet rods are also very nice, but they're about twice as much as the Eagle stuff. If you're looking to make anywhere over 800 I would recommend stepping up to the Lunati rods.
Hope you don't mind the article, I'm bored.
Hopefully future 408 guys will use the search and read the info here.
BTW the 402 will be very popular soon.
Probally a 406 will be even more popular once they start
boring the LS2 block 4.020.
I know my next motor would be a 402 as long as all this ls2 swap to ls1 works ok, I hate the weight of the iron but it does/has taken alot of punishment from me, also do you think it would be safe to bore it out that much? .020 on an aluminum? On the current ls1's the max safe/cleanup bore is only .006 which is why I ask.
It is a little bigger but me personally I would be afraid to bore it over too much. Aluminum isnt as strong as iron and it would just be a nice peace of mind to have the iron block under the hood.
on my 408, my "stage II" heads with 2.02/1.60 valves and 'only' flow 293 @ .600 and put down 542/535 on they dyno and traps 130+
midlift numbers are what counts and valve size isn't a huge factor, IMO
damn thanks for all this info this really helps me choose the right crank and pistons for my set up. what type of heads and cam do you guys think would be the best for this moto?
We have talked about this before. You are running 13 to 1 compression, or some ungodly high number, on a strip only drag car. I am only running 11 to 1. Plus you have bigger headers and better intake and all. I am going to do a head swap to stage 3 heads and change nothing else and I will get back to you and let you know how much it changes.
This question is almost impossible to answer. Whats streetable to one guy is not at all streetable to the next. Alot of people say that a trex isnt streetable, but I street mine every day and dont think twice about it.
Well, I street a 'big' cam every day and never give it gas when im at the light........unless theres a mustang next to me
They have done amazing things with tuning.
