Building a 408ci
I know we have. my compression is more like 12.3:1 and I'm running 1 3/4 headers. I just think your heads aren't the problem you think they are. by your statement, you current heads are BETTER than mine. that what I'm trying to point out.
looking forward to hearing your results
I would also love to put on my AFR 225's and see what mine does. looking forward to hearing your results
Whats wrong with the exhaust system?? Besides needing bigger headers. The true duals are 3" all the way out throgh an X pipe.
http://www.automotiveperformance.net/cylinderhead.htm
a big cam can be made streetable, like it was stated before, with the right tune...the real question is wat size cam is optimal for a 408. I've been researching and i still havent found a conclusion to what it may be. I can only see wat other guys are runing and compare. THe 408 iron is heavier but the security of the material is well worth the compensation. Also, i think you can go .060 on the iron if you wanted to go bigger.
The cam im installng is 244 248 .600 .600 114...its the same cam that mike k. is running (dude, if you dont mind me posting it...) and it has produced great numbers for his setup. Also, stage 3 heads with the 2.08/1.60 sizing will be a better match for the 408 since you need the added flow for the added cubes IMO.....also a 90mm intake, fuel system upgrade will make it all make optimal...........and if in doubt, you know you can spray the hell out of it (safely), possibly with progressive NOZ controller and have the peace of mind that the motor will hold!!
personally, dont go for something that u might not need.......i think that your cam is holding you back though...........do a cam swap and see wat happens........them go heads.you should be at 500rwhp........(question, those numbers were on a dynojet or mustang.....dynojet right?) im still not sure if going to a 17/8 header will make that much more of a difference but i would hold off until the intake is done IMO
enjoy and keep tuning...........LAterZ
CHP magazine did a great write up about APE's 408 that you can read on my webpage in the magazine section @ www.avigdor.net . When will it be ready?
do you have complete flow numbers on your heads?
here's my intake/exhaust #'s
.100 70 51
.200 149 110
.300 218 154
.400 264 197
.500 286 222
.550 292 228
.630 293 233
these are 5.7 heads with 2.02/1.60 valves.
.100 70 51
.200 149 110
.300 218 154
.400 264 197
.500 286 222
.550 292 228
.630 293 233
Unfortunately I only know the 600 flow numbers. I got them used but called Jay and talked with him about them and he said they were an older design of port he was using but should work ok for my 224 cammed 346. I then had to rebuild and went to a 408 so I dont know if these heads are good at all for what I have.
