ok i clayed the P to V
A standard Hyd. Roller has preload.
suppose that you have 40 thou of preload.
If you use a ballpoint pen spring ( kidding), or flowbench style spring, you get the preload that is supposed to be in the lifter, now in the valve, only multiplied by your rocker ratio. (1.7)
BEcause of this, you are starting with 40 thou * 1.7= ~ 70 thou that the valve is open. So starting with the valve 70 thou open, and you have 60 thou of clearance ( in reality), your motor will not turn over. OR, suppose you have 160 thou of clearance, you will now only have 100 thou.
Make sense?
If you use a hydraulic lifter and a standard spring, you will compress the lifter such that you will have more clearance, untill the lifter pumps up. ITs not much, but it sure puts a snag in the install.
Hope that helps
Mikey
