got my cam installed today
.the guys i had put it in started around 9:30 am and didn't get finished until after 6pm.
the crank enough to get the crank bolt in a couple threads into the block. NOTE: if you plan on using the stock crank pully on your cam install, think again. once the cp was it things went pretty smoothly. now i just need it to be spring time so i can
down the track and see how much of a difference it makes. Predator-the guys doing the install heated it up 3 times before they got it to go in.
