Cams
Old Nov 22, 2004 | 04:54 PM
ZL1Killa's Avatar
Default Cams
Ok my car a 2001 trans am ws6 6-speed has dynoed at 356hp and 375tq at the wheels and I want to go with a heads and cam package.
I have been recommended a 224/228 114 lobe separation 4 degree advance and 570-580 lift.
I want 400+ at the wheels along WITH 400+ torque at the wheels, none of this bullshit 450hp and 380tq.
Has anyone accomplished this??? Could you tell me your cam specs if you have?
Old Nov 22, 2004 | 04:56 PM
Turo's Avatar
I have been recommended a 224/228 114 lobe separation 4 degree advance and 570-580 duration.
i hope you mean 570-580 lift! with good heads and a 224 cam that should be achievable. do a search for 224 cams in the dyno results section and see what the results were with different combos.
Old Nov 22, 2004 | 09:41 PM
ZL1Killa's Avatar
yeh oops
Old Nov 22, 2004 | 09:48 PM
66deuce's Avatar
man,that's damn good numbers with just bolt ons.i would think you could easily make your goal with that the cam and heads.
Old Nov 22, 2004 | 10:09 PM
TheBlurLS1's Avatar
That's what she said...
you could make that with a 231/237ish CAM ONLY. why not go with a bit bigger cam if you're going to do heads too?
Old Nov 22, 2004 | 11:51 PM
CaptUSA's Avatar
What are your drivablity goals? A 222 or 224 cam on a 114 or 115 lsa when used with a decent head should put you right at the power you're looking for and still be Very nice to drive.
Good luck on your decision!!
There is a TON of info on this subject in the archives. A search will yield you much knowledge.
