ARP head studs > 6 or 12 point best?
Old Nov 22, 2004 | 04:55 PM
V8er's Avatar
Default ARP head studs > 6 or 12 point best?
I am ordering ARP head studs for my LS1. Does it matter if I get the standard hex 6pt or the 12pt? The 12pt is more money but are they better?
Old Nov 22, 2004 | 05:01 PM
Bo White's Avatar
The 12 point nuts are lighter(not a big deal, couple of grams) and have more contact on the socket for better grip.
Old Nov 22, 2004 | 05:40 PM
C4VetteLS1's Avatar
either will do fine....i prefer the 6pts
Old Nov 22, 2004 | 05:43 PM
Beast96Z's Avatar
The 12 pt's also distribute the load across the nut better. Of course you need a 12 pt. socket also.
Old Nov 22, 2004 | 06:02 PM
V8er's Avatar
Yikes you guys are getting very fussy about these ARP parts! I think for my sub-1000hp LS1 the studs with 6pt nuts will be more than enough
Old Nov 22, 2004 | 07:00 PM
pdd's Avatar
pdd
i got the 6pt because of more bite on the nut
Old Nov 22, 2004 | 07:22 PM
NA$TY-TA's Avatar
12 pts here because at the time the 6 pts were backordered....
Kyle
Old Nov 22, 2004 | 11:54 PM
CAT3's Avatar
Restricted User
pdd, technically speaking 6pt has less bite, less contact area for torque applications. 12pt distributes loads more even, and have greater surface area.
Unless you are going extemely wild 6pt are more than enough.
Old Nov 23, 2004 | 03:15 PM
technical's Avatar
That's why they make washers.
Old Nov 23, 2004 | 04:43 PM
GuitsBoy's Avatar
I think they mean it as more contact with the socket. Since only the edges closest to the corners actually make contact, having more corners means more contact. IIRC, ARP nuts and bolts have round washer bottoms anyway.
If you still torque both to the same torque spec, whats the difference? Like it was said, maybe a couple of grams less mass across the entire set.
Old Nov 23, 2004 | 04:59 PM
technical's Avatar
What do you mean by round washer bottoms?
Old Nov 23, 2004 | 05:00 PM
Bo White's Avatar
I like round washed bottoms......
Old Nov 23, 2004 | 05:01 PM
GuitsBoy's Avatar
Sorry, Brain Fart. The threads about studs. I was thinking nuts / bolts.
Old Nov 23, 2004 | 05:30 PM
pdd's Avatar
pdd
ME TOO
Old Nov 23, 2004 | 05:55 PM
Slowhawk's Avatar
LS1Tech Sponsor
I like 6 point's because there is less chance of stripping the nut.(wrench side)
Old Nov 23, 2004 | 07:17 PM
Damian's Avatar
LSX Mechanic
6pts by far....
Old Nov 23, 2004 | 08:43 PM
jrp's Avatar
jrp
SN95 Director
i went 6pt because of the price.
Old Nov 24, 2004 | 07:51 AM
SideStep's Avatar
Same here......
Old Nov 24, 2004 | 08:00 AM
GuitsBoy's Avatar
I actually think this is backwards. Since its only the corner that contacts te wrench, 6pts have a greater chance of rounding off than 12 points do. Can somebody back me up here?
Old Nov 24, 2004 | 08:03 AM
Bo White's Avatar
I already have. The points are like splines of an axle, more spline count-more contact. Also like threads, fine threads are stronger than course threads.
