valvespring preload
1- Custom length pushrods (quasi impossible as you would require a different lenghth on every valve to achieve optimum)
2- shimming the springs.
If'n you used pushrods to adjust valve spring preload, to raise preload, you would have the valves open. Different length pushrods are used to correct valve train geometry problems.
Shimming the springs is the generally accepted way of adjusting seat pressure. In order to do this, you need a spring tester and you can get by with a snap gauge, preferably a height micrometer, though. For example, say the cam company wants 114 lbs of seat pressure, compress the spring in the spring tester until it reads 114 lbs, then measure the height of the spring while it is compressed. You then add or remove shims at the spring seat until the distance from the shim to the underside of the retainer matches the length of the spring when compressed to the 114 lbs.
Oem LS1 cam base circle diameter 1.550", subtracting new cams smaller base circle diameter (specs on cam card), divided by 2. Now subtract your answer from the 0.090" factory preload setting. This will be your preload using stock length pushrods and stock rockers. Everything else being stock specs.
Chris
Just a bad choice of words. What you were looking for was lifter preload.
Brad
Yeah, I thought at first we were pre-loading the inner spring to simulate a retainer step so we could check pressure on the Rimac, but this thread didn't go there.
Chris
Now that I read the first post I see what you guys are talking about. I didn't pay attention to the "spring preload" comment. My reply was assuming we are talking about lifters and ways to adjust preload with stock rockers.
Your preload is fine if you did the install correctly and you dont have any bad lifters, these fast ramp cams just make alot of racket. I like the sound personally.One question. Did you also install hardened pushrods or did you stay stock.
Noisey valvetrain sounds like lifter preload being too light...At least in my case, after my cam install, the valvetrain tapped like crazy when the engine warmed up...Added a set of adjustable roller rockers and now the valvetrain is business like, but quite and no...TAP, TAP, TAP...
Peace...Gman
Peace...Gman
Anyway he could have a bent pushrod, a bad lifter, or any other number of valvetrain problems that would cause the tap that should be ruled out before cashing out on aftermarket rockers. That's why I asked about the pushrods.
Peace...Gman
There is another thread about the ticking that bring up the point of oil pressure, What is it like at idle?
Besides...If it was an oil pressure problem, when the engine was reved up, the ticking would dissappear...In my case the ticking was always present, at all rpms...But, it was not present when the engine was cold...I'm not sure what the base circle diameter of the G5x3 cam is vs. the stock LS6 cam, but I know that they put 7.35" long pushrods in with the cam swap...This is when the ticking really got loud...When I swapped the rockers out...I can tell you that the rockers were extremely loose, some of them had no preload pressure from the spring in the lifter whatsoever...
It's easy enough to check the preload...Take one rocker that the valve is totally closed, loosen the rocker bolt up until there is no pressure on the spring, then finger tighten the bolt to take up the slack...Then count the total number of turns it takes until the bolt seats the rocker in it's cradle...Remove the bolt and measure the thread spacing, multiply this by the number of turns it took to tighten the bolt, and there you have your preload measurement...
Peace...Gman
