Please pick my cam for me. Is this one ok?
Thank you all.
Thank you all.
LS6 intake (Comes on 2001 Camaro's)
K&N Air Filter
Whisper High Flow Induction lid
Granatelli Mass Air Flow Sensor
Superior 3.73 Rearend Gears
Auburn Carrier
Free Ram Air Cutout
Nitto 555R's Drag Radials
Corsa Catback Exhaust
Hypertech 160 Degree Thermostat
Throttle Body Bypass
SLP Strut tower brace
SLP Sub Frame Connectors
Powerslot Slotted Rotors
Durastop Performance Brake Pads
B&M Deep Transmission pan with Transmission Drain Plug
Lower Control Arms
FLP Long Tube Headers
Taylor Thundervolt 10.4mm wires
NGK TR-55 spark plug wires
Upper and Lower Panhard bars
Hp Tuners Custom Programming
Spohn Adjustable Torque arm with Driveshaft loop
Yank PY3600E Torque Converter
Energy Suspensions Poly Transmission Mount
QTP Electronic Cutout
Smooth Bellows
Custom ported Heads
Custom Grind camshaft
Asp underdrive Pullies
Felber racing is doing my heads. I may take you up on that cam offer. My car IS a daily driver, I do not currently have a power adder, but shortly after doing heads/cam I would like 100 MAYBE 150 shot of nitrous. I want most of my power NA, but I want the nitrous to help dip me into the 10's. Please pm or email me prices. Michaelozorowsky@hotmail.com thank you.
K&N Air Filter
Auburn Carrier
Free Ram Air Cutout
Lower Control Arms
Smooth Bellows
Custom ported Heads
As said above,match your Cam with the heads.I prefer AFR's now since I've seen unreal results personally with them(no ported head has been close that I've tested)
Tell the misses I said
