Stock Verter and Manifolds which Cam??
MTI A1 209/216 .533/.552 116LSA
Huge increase in torque, nice idle, and a good jump in top end.
Nowadays with the new grinds, I would choose something a little bigger:
216/224, .560/.560 114LSA (faster ramps should give it similar idle, but a nice jump in power over the A1). If you were running long tubes, I would not recommend such a wide split in cam pattern, but with stock manifolds, you will run better with a little more exhaust bias.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Patrick G, thank you for the insight. Think I would go slower with a even split cam like the Stealth I, 220-220? Realize it has more lift at .580 but, this gets to the heart of another question I have, since I will have stock manifolds should I only look for exhaust biased cams? I am completely open to a custom cam as well. My crude understanding is more fuel and air, I guess how much fuel would my setup handle before going backwards, and should be considered, and is, but not to many people are opting for a configuration like mine, so looking for help.
If you decide to go looser on converter, you can go a hair wilder on the cam.
It's my opinion, that you need to have a more biased exhaust lobe when running stock manifolds and closed exhaust. It's the way GM builds them and the way Lingenfelter would recommend them for a daily driver with stock converter. I've been kicking around a similar combination for my car, but I would probably go a little wilder on the cam since I have a 6 speed (but still stock exhaust manifolds). I've definitely put a lot of thought into your question, so don't think I'm just giving you a wild *** guess.
The other cam that I think could get you there would be the 212/218 114 cam.
Or I might get shot for this one but I've used it before
216/220, .525/.532 114 COMP Cam XR269HR . Very tame and good power, I made 400 rwhp with it H/C, pulley and LT's on M6.
The IAC and throttle follower in my drive by wire throttle body would sometimes bite me and give me idling fits when pulling up to a stop - but I get that now with my 210/218 112 when the computer goes through it's little (alleged) learning process after I mess with things.
Also, for what it's worth, I love the 210/218 .531/.531 112 cam I have in there now. It's a VHP grind that I've been ranting and raving about.
Power from 1,900-6,000. Lots of low end. It's a little soft under 1,500 rpm which I can feel with my stock converter when I'm putting around taking it easy, or driving with the stock lockup points of 35mph. It would be BARELY noticeable in a nice lightweight car. Anytime you put your foot into it with any sort of authority it easily gets past that soft area and pulls very sharply. I'm able to flash my stock converter to 2,100, if that's any idication of the low end power available.
It's a fun street cam. It's nice to float in an out of the area where the cam wakes up between 1,700 and 1,900 or so - the exhaust note changes and you feel the torque pick up.
This cam, cat back, e-fans, and my crappy tuning got my slug of a truck at full street weight (5,400lbs?) and 3/4 tank of gas down the track at 14.5 at 92 with a 2.13 60'.
FWIW, if you're dead set on leaving everything stock, go with my cam in sig. Comp 212/218 114. Great torque and acceptable top end.
I've got a Yank 2600 (the mild 2800 for you F-bod guys) sitting at home - I just have no desired to put it in.
BTW, the time in my sig is with the 3500 stall, headers, TR224, untuned, ~3650 raceweight. That's using 275 Nitto DRs.
If you have an A4, the mods sequence should be headers, converter, cam. I talk from experience.
