What cam with 02 LS6 springs.....
I want to use the 02 LS6 springs. I want a cam will sound pretty radical. Is there anything out right now that would fit the bill.... I realize it will have to be a low lift cam and pretty wussy ramp rates.... That is fine, as long as it has the sound i am looking for.
I currently have the 02 LS6 cam and have seen great results. i just want the lumpy idle. I previously had the Hot Cam and really miss the sound.
Any suggestions? i basically want the hot cam sound with the gains of the LS6 cam and will hold the 02 springs ok.
i am not looking for gains, just dont want to loose anything.
Thanks
Thanks
Thanks for the reply.... i used to live in Greenville. U?
As for buying another hotcam.... i have thought about it ....but in all honestly....i making better power right now than what i did with the Hotcam. However i have given it some thought
Right now i'm giving some serious thought to the CC 220/224 .530/.534 on a 112
I think this cam should do well with the 02 ls6 springs. and i think it would have a choppy idle very similar to the T1 cam.
Anyone running this Comp cam?
why not go with the ASA hotcam 226/236 .525/.525 110LSA SSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS SSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS SSSSSSSSSSSSSSS AAAAAAAAAAAASSSWHY DONT PEFRPFORMANCE DANISBEEN MEETINED S. YOU YOW KNOEW THAT THIS CAM ISA PERVICT,. lOOK AT THE FActsbetrween the ls6 cam a
and comare it to the assa cam.
nd the asa hot cons. asa .525.lift and high dur.this duratin alomg with a 110 lobe sep angle eqalls superiop power whith the ls6 springd
