383 question
Old Nov 27, 2004 | 07:34 PM
chase311's Avatar
Question 383 question
ok i get too many different answers to this question..im building an ls6 motor and i wanna know if you want a 383 do you have to bore the cylinders....i know the stock crank stroke is 3.622 w/ a 3.905 inch bore..now if i went to a 4.0 inch stroke with a 3.905 inch bore would that work on a ls6 block...
Old Nov 27, 2004 | 09:44 PM
CHRISPY's Avatar
check your PMs I wrote you back
Old Nov 27, 2004 | 09:45 PM
cyphur's Avatar
actually the stock block has a 3.90 bore and 3.622 stroke. its when you do the .005 hone that you acheive the true 383 w/a 4" stroke. so the answer is yes, you have to hone the block for a 383 stroker.
Old Nov 27, 2004 | 10:29 PM
Beast96Z's Avatar
Actually, it's 3.898"
Old Nov 28, 2004 | 10:38 AM
VSGLS1's Avatar
You will have to have a machine shop hone the cylinders for the 3.905 pistons. It shouldn't cost too much.
Old Nov 28, 2004 | 11:04 AM
cyphur's Avatar
I know. Next time I'll be more precise in my posts
