how to fix collapesed lifters
Originally Posted by flippincamaro
I had the guy that ported the heads check the valves all good. It was the 2 degrees advance that we did on the cam with the adjustable timing chain that did it.
2 degrees made like a 1/4 of an inch diffrence. They are not hitting now
funny but this is what happened i dont know if my buddy screwed the timing up the first time. and turned it to much. but i got the guy that ported the heads to check my valves there wasnt anything wrong with them i can send whoever a pic of the drivers side pistons after we pulled the head back off. it is with a digital camara. Maybe i got lucky or this is why it is running with no power?
#32
#33
Thanks all my buddy talked to his boss about the two degrees it was way out of time if you go by the crank pulley for the timing chain i didnt understand it but nothing hits now. So i will do a compression test tomorrow or thursday thank you all for all the help also i am getting the computer programmed next week.
