Stroker guys inside..... Oil consumption Q+A within
Originally Posted by Cammin BeaSSt
Doing a lil research here with multiple setups.... Please post up the following info.
436 stroked and bored
cubes
stroke/bore
intake(LS6, BBK, sheet metal, etc)
heads(supplier)
shop who built your setup(not NEEDED, optional)
average miles driven
average oil consumed
smoke... decel/accel etc etc
Just looking to see if different setups eat more oil than others and determine any trend in possible causes.
Thanks guys!!
cubes
stroke/bore
heads(supplier)
Thanks guys!!
4.100 biore...4.125 stroke
LS6 intake..catch can and valley cover
Agostino Racing Engines built it
250 miles per week
LS1 ported heads
383
4.00 stroke/ 3.905 bore
LSX 90
TEA ported AFR castings
TSP< I am the second owner. Also, previous owner installed LSX 90, AFR/TEA heads
First month I had it I put 5k miles on it. Now, about 250 a month.
Consumes about a qt every 1k miles with lots of oil in the catch can. I also pulled the LSX and there was oil in the ports.
Never really noticed any smoke.
LSX 90
Originally Posted by moyam01
There seems to be a rumor that stoker engines consume oil. This is just not true. If it was properly built, the gaps set properly, seals are sealing ang gasktes are good, it should consume none to very little oil
Mine uses more than it should. No, I dont see any blue smoke when it runs. No oil leaks can be found either.
I believe most use more than non strokers. Talking to engine builders leaves me to believe its more of the norm than the exception. I had mine to a shop yesterday where we discussed this issue.
I think a winter time purchase will be an A&A vacuum pump. I may try a catch can to keep the oil of of the intake in the mean time.
JMHO
JMHO
