Heads/Cam swap start-up issue help needed
Old Nov 30, 2004 | 01:31 PM
GoatChs's Avatar
Default Heads/Cam swap start-up issue help needed
My installer just installed my Absolute Speed Stage II heads and a Comp 224/581-114 cam in my '04 GTO/M6, along with a set of Stainless Works LT headers. When we turned the key the first time the engine started great and after a minute or so settled into an idle of approx 800 rpm. After another couple minutes we ran the idle up to 1500-2000 with intent to hold it there for a couple minutes then bump to 3000-3500 for another minute or so.
After approx holding the throttle at 2000 rpm for a little over a minute, the left bank (only the driver's side) header started to glow...it was getting hot. We checked everything over (Plugs are light gray & dry, O2 connections good, fuel rail connections good, etc.) and tried it again...same thing again. We connected up AutoTap and everything showed connected and operating normal. We put it on the rack and noted that the left cat was also very hot so we thought it might be plugged...removing the cats and starting the engine had the header glowing again...not a plugged cat issue.
The heads were ordered as standard deck height and we installed new 7.40" pushrods. Checked for leaks around the intake, and even installed new intake manifold gaskets. Still a problem. It is only happening on the left side...
We're scratching our heads...any ideas on what to check from here?
Old Nov 30, 2004 | 02:46 PM
GoatChs's Avatar
No ideas?
Old Nov 30, 2004 | 03:36 PM
777's Avatar
777
i can't think of anything...look's to me like you have done all that i know of...very strange
Old Nov 30, 2004 | 03:51 PM
AdamSS's Avatar
crappy headers..... ???? I can't imagine thick stainless steel getting red-hot from exhaust fumes.....
Old Nov 30, 2004 | 03:53 PM
GoatChs's Avatar
Yeah...serious head scratcher.
Old Nov 30, 2004 | 03:55 PM
Gary Z's Avatar
You didn’t mention checking for leaks in or around the headers. You might also swap oxygen sensors.
Old Nov 30, 2004 | 04:04 PM
Squintz Palladoris's Avatar
Sounds like that bank is lean.
I have seen headers glow like that before. But that was on a carb setup and the cause of it was not enough initial timing. I dont see how one bank could be getting more or less ignition timing than the other so thats pretty much out of the question.
Sounds like a good place to start.
I would also check to see if there is a vacuum leak from the intake though that would have caused some Idle problems.
Only other thing I could think of would be the head on that bank has smaller combustion chambers and is making more compression.
All of these are shots in the dark man. Post up when you figure it out.
Brad
Old Nov 30, 2004 | 04:44 PM
GoatChs's Avatar
The O2 sensors showed good on AutoTap, but that is a quick & easy swap that the installer said he was going to try today. The vacuum leak around the intake was one of the first checks, although they did it the "shade tree" method with cigarette smoke, it didn't show any "suction" into the mating surfaces.
And, uncoated headers will glow pretty easily when the heat gets cooking.
Old Nov 30, 2004 | 04:49 PM
Try the other shade tree method.
Use carb cleaner or brake parts cleaner. Spray it around the intake ports or anywhere else tou may suspect a vacuum leak. If the idle changes you have found your leak.
Brad
Old Nov 30, 2004 | 05:12 PM
GoatChs's Avatar
Will do!
