Crank Pulley
Old Nov 30, 2004 | 01:33 PM
WS6 RULES's Avatar
Question Crank Pulley
Is there any reason I can not use an impact gun to remove and replace the bolt that holds on the crank pulley? Thanks
Old Nov 30, 2004 | 02:15 PM
LOnSLO's Avatar
You can use an impact to remove it, but you need to use a 1/2" torque wrench to reinstall.
Old Nov 30, 2004 | 03:10 PM
code4's Avatar
There are some horror stories here, do a search. I personally took every precaution I knew of when I installed my asp & it was easy. I use air tools all the time but I didn't on my pulley but many have.
Old Nov 30, 2004 | 04:16 PM
Viper's Avatar
I used an electric impact gun (Sears) to break the pulley bolt free once the motor was out of the car.
Old Nov 30, 2004 | 07:21 PM
~JOSHUA's Avatar
YES TO REMOVE, NO TO PUT ON DON'T FORGET TO USE A NEW BOLT!
Old Dec 1, 2004 | 12:17 AM
WS6 RULES's Avatar
Thanks everyone for your replys. The advise sounds good, I'll follow it.
