Spring Pressures vs Lifters, head milling vs. Pushrod length??
Old 11-30-2004, 08:17 PM
Restricted User
CAT3's Avatar
Default Spring Pressures vs Lifters, head milling vs. Pushrod length??
Ok, a few questions I couldnt get definite answer using search on:
1) Whats the recommended safe operating range of seat/open pressure for stock lifters?
*I have PP Gold Duals, now with stock lifters, I believe its 140/400 good to .650" and I have TSP 231/237 .595/.598 @ 112* lsa cam*
2) How to determine pushrod length after milling heads?
*heads milled .010". Stock head gasket was .054", new head gasket is .065" cometic. So that should be good. Stock rockers, stock lifters. Still would like to know how to determine legth requirement, like milled heads .030" using .041 gaskets, go with the 7.350 instead of 7.400"*
TIA.
Morels Lifters look nice BTW, maybe around the corner!
Charlie
Old 11-30-2004, 09:15 PM
66deuce's Avatar
don't know the operating range for the stock lifters,but was told by terry when he was at patriot that the stock lifters would work fine with the patriot golds with my tr220.i would call them up to make sure.i would get an adjustable pushrod length checker to determine the right pushrod length.i bought mine from thunder racing.
Old 11-30-2004, 11:09 PM
jrp
SN95 Director
jrp's Avatar
my PP golds independently checked out 145 seat - 363 @ 1.200 (i think, would have to check the sheet to make sure).
whats the base circle of the TSP?
Old 11-30-2004, 11:18 PM
Restricted User
CAT3's Avatar
Not sure, cam card in the car in Hawaii and I am unfortunately in ***-ghanistan! Anyone want to help chime in on this one!
Old 12-01-2004, 08:50 AM
gollum's Avatar
You want the lifter plunger to compress between 0.045-0.090.
